error compilando para tarjeta arduino uno
CONSULTA error compilando para tarjeta arduino uno
cordial saludo a todos
soy nuevo en programación con arduino, y deseo hacer un programa para trabajar con unas celdas de carga y sus amplificadore HX711, verifico todo el codigo a continuacion y me sale : Error complilando para tarjeta arduino uno.
Quisera por favor si alguien pudiese ayudarme a encontrar el error, o explicarme a que se debe este
gracias
//HX711-multi.h
#ifndef HX711_MULTI_h
#define HX711_MULTI_h
#if ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
class HX711MULTI {
private:
byte PD_SCK; // Power Down and Serial Clock Input Pin
byte COUNT; // The number of channels to read
byte *DOUT; // Serial Data Output Pin
byte GAIN; // Amplification Factor
bool debugEnabled; // print debug messages?
long *OFFSETS; // used for tare weight
// Array of values used to convert the integer digital data to weight (in grams, ounces,etc.)
float *SCALES;
public:
// define clock and data pin, channel, and gain factor
// channel selection is made by passing the appropriate gain: 128 or 64 for channel A, 32 for channel B
// count: the number of channels
// dout: an array of pin numbers, of length 'count', one entry per channel
HX711MULTI(int count, byte *dout, byte pd_sck, byte gain = 128);
virtual ~HX711MULTI();
// returns the number of channels
byte get_count();
// check if HX711 is ready
// from the datasheet: When output data is not ready for retrieval, digital output pin DOUT is high. Serial clock
// input PD_SCK should be low. When DOUT goes to low, it indicates data is ready for retrieval.
bool is_ready();
// set the gain factor; takes effect only after a call to read()
// channel A can be set for a 128 or 64 gain; channel B has a fixed 32 gain
// depending on the parameter, the channel is also set to either A or B
void set_gain(byte gain = 128);
// waits for the chip to be ready and returns a reading
void read(long *result = NULL);
// same as read, but does not offset the values according to the tare
void readRaw(long *result = NULL);
// set the OFFSET value for tare weight
// times: how many times to read the tare value
// returns true iff the offsets have been reset for the scale during this call.
// tolerance: the maximum deviation of samples, above which to reject the attempt to tare. (if set to 0, ignored)
bool tare(byte times = 10, uint16_t tolerance = 0);
// puts the chip into power down mode
void power_down();
// wakes up the chip after power down mode
void power_up();
void setDebugEnable(bool debugEnable = true);
/* NEW FEATURES BELOW */
// Method to return the array of SCALES values
float* get_scales();
// Method to set the array of SCALES values
void set_scales(float *_scales);
// Method to actually get the weight data (does not return it, but changes the parameter passed by reference)
void get_units(double *result = NULL);
/* END OF NEW FEATURES */
#endif /* end HX711_MULTI_h */
#include <Arduino.h>
#include <HX711-multi.h>
HX711MULTI::HX711MULTI(int count, byte *dout, byte pd_sck, byte gain) {
PD_SCK = pd_sck;
DOUT = dout;
COUNT = count;
debugEnabled = false;
pinMode(PD_SCK, OUTPUT);
for (int i=0; i<count; i++) {
pinMode(DOUT[i], INPUT);
set_gain(gain);
OFFSETS = (long *) malloc(COUNT*sizeof(long));
// Allocate memory space for the SCALES array when creating a new HX711MULTI object
SCALES = (float *) malloc(COUNT*sizeof(float));
for (int i=0; i<COUNT; ++i) {
OFFSETS[i] = 0;
// Initialize the SCALES array with 1's to avoid dividing by 0
SCALES[i] = 1.0;
HX711MULTI::~HX711MULTI() {
free(OFFSETS);
// Recover the memory space allocated earlier when deleting the object
free(SCALES);
bool HX711MULTI::is_ready() {
bool result = true;
for (int i = 0; i<COUNT; ++i) {
if (digitalRead(DOUT[i]) == HIGH) {
result = false;
return result;
void HX711MULTI:Confundidoet_gain(byte gain) {
switch (gain) {
case 128: // channel A, gain factor 128
GAIN = 1;
break;
case 64: // channel A, gain factor 64
GAIN = 3;
break;
case 32: // channel B, gain factor 32
GAIN = 2;
break;
digitalWrite(PD_SCK, LOW);
read(); // a read is needed to get gain setting to come into effect.
byte HX711MULTI::get_count() {
return COUNT;
bool HX711MULTI::tare(byte times, uint16_t tolerance) {
int i,j;
long values[COUNT];
long minValues[COUNT];
long maxValues[COUNT];
for (i=0; i<COUNT; ++i) {
minValues[i]=0x7FFFFFFF;
maxValues[i]=0x80000000;
for (i=0; i<times; ++i) {
readRaw(values);
for (j=0; j<COUNT; ++j) {
if (values[j]<minValues[j]) {
minValues[j]=values[j];
if (values[j]>maxValues[j]) {
maxValues[j]=values[j];
if (tolerance!=0 && times>1) {
if (abs(maxValues[i]-minValues[i])>tolerance) {
// one of the cells fluctuated more than the allowed tolerance, reject tare attempt;
if (debugEnabled) {
Serial.print("Rejecting tare: (");
Serial.print(i);
Serial.print(") ");
Serial.println(abs(maxValues[i]-
minValues[i]));
return false;
// set the offsets
OFFSETS[i] = values[i];
return true;
// reads from all cahnnels and sets the values into the passed long array pointer (which must have at least 'count' cells allocated)
// if you are only reading to toggle the line, and not to get values (such as in the case of setting gains) you can pass NULL.
void HX711MULTI::read(long *result) {
readRaw(result);
// Datasheet indicates the value is returned as a two's complement value, so 'stretch' the 24th bit to fit into 32 bits.
if (NULL!=result) {
for (int j = 0; j < COUNT; ++j) {
result[j] -= OFFSETS[j];
void HX711MULTI::readRaw(long *result) {
int i,j;
// wait for all the chips to become ready
while (!is_ready());
// pulse the clock pin 24 times to read the data
for (i = 0; i < 24; ++i) {
digitalWrite(PD_SCK, HIGH);
if (NULL!=result) {
for (j = 0; j < COUNT; ++j) {
bitWrite(result[j], 23-i, digitalRead(DOUT[j]));
// set the channel and the gain factor for the next reading using the clock pin
for (i = 0; i < GAIN; ++i) {
if (NULL!=result) {
if ( ( result[j] & 0x00800000 ) ) {result[j] |= 0xFF000000;
else {
result[j] &= 0x00FFFFFF; // required in lieu of re-setting the value to zero before shifting bits in.
void HX711MULTI:ConfundidoetDebugEnable(bool debugEnable) {
debugEnabled = debugEnable;
void HX711MULTI::power_down() {
void HX711MULTI::power_up() {
float* HX711MULTI::get_scales() {
// Just return the SCALES array (property of the object)
return SCALES;
void HX711MULTI:Confundidoet_scales(float *_scales) {
// Just set the SCALES object property with the array parameter
SCALES = _scales;
void HX711MULTI::get_units(double *result) {
// Use the library's built-in read() method to obtain the weight as an integer value and save it in a temporary array
long int rawResult[COUNT];
read(rawResult);
// Convert each value of the temporary array to weight data using the SCALES property and save it to the result array passed by reference
for (int i = 0; i < COUNT; ++i) {
result[i] = ((double) rawResult[i]) / SCALES[i];
// arduino_get_data_def.ino
#include "HX711-multi.h"
#define CLK A0 // clock pin to the load cell
#define N 3 // # of channels
#define DOUT1 A1 // data pin to the 1st load cell lift 1
#define DOUT2 A2 // data pin to the 2nd load cell lift 2
#define DOUT3 A3 // data pin to the 3rd load cell drag
#define TARE_TIMEOUT_SECONDS 4
// INSERT THE VALUES CORRESPONDING TO YOUR MODEL
// Inputs
double x01 = 0.02; // distance between the leading edge and the first load cell [m]
double v = 10; // speed of the wind [m/s]
double rho = 1.225; // density [kg/m^3]
double S = 0.04; // wing surface [m^2]
double C = 0.2; // chord length [m]
//CALLIBRATION OF THE BALANCE
// To re-calibrate the balance (if a load cell is replaced or one of the existing changes its behavior) write a 1.0 in the corresponding cell of measurements[]
// vector and tare the balance (this can be done sending any character to the Arduino through Serial Monitor).
// Then read the value of 'WEIGHT DATA BELOW' corresponding to the load cell at the program when a known weight is placed at the load cell.
// Substitute the 1.0 by (value obtained)/(known weight [g]).
float measurements[N] = {(-10000/21.2), -8600/21.2, 40750/21.2}; // measured SCALES parameters
// MAIN CODE, DO NOT SAVE THE CHANGES MADE HERE
// Init
byte DOUTS[N] = {DOUT1, DOUT2, DOUT3};
long int results[N];
double weights[N];
double go = 9.80662;
double lift;
double drag;
double Mle;
double F1;
double F2;
double x02 = 0.041;
double x12 = x01 + x02;
double xcp;
double Cl;
double Cd;
double Cm;
HX711MULTI scales(N, DOUTS, CLK);
void setup() {
Serial.begin(115200);
Serial.flush();
tare();
scales.set_scales(measurements);
void tare() {
bool tareSuccessful = false;
unsigned long tareStartTime = millis();
while (!tareSuccessful && millis() < (tareStartTime + TARE_TIMEOUT_SECONDS
* 1000)) {
tareSuccessful = scales.tare(20, 10000); //reject 'tare' if still ringing
// void sendRawData() {
// scales.read(results);
// for (int i = 0; i < scales.get_count(); ++i) {
// Serial.print(-results[i]);
// Serial.print((i != scales.get_count() - 1) ? "\t" : "\n");
// delay(1000);
void sendWeightData() {
scales.get_units(weights);
Serial.print(-weights[i]);
delay(1000);
void loop() {
// Serial.println("RAW DATA BELOW");
// sendRawData(); // this is for sending raw data, for where everything else is done in processing
// Serial.println();
Serial.println("WEIGHT DATA BELOW");
sendWeightData();
Serial.println();
//calculate forces in N
F1 = weights[0]*go/1000; //[N]
F2 = weights[1]*go/1000; //[N]
lift = F1 + F2;
drag = (weights[2])*go/1000; //[N]
Mle = x01 * F1 + x02 *F2; // [Nm]
xcp = (x02 * F2 + x01 * F2) / (F1 + F2)*1000;
//aerodynamic coefficients
Cl = (lift*2)/(rho*v*v*S);
Cd = (drag*2)/(rho*v*v*S);
Cm = (Mle*2)/(rho*v*v*S*C);
Serial.print("lift = ");
Serial.print(lift);
Serial.println(" [N]");
Serial.print("drag = ");
Serial.print(drag);
Serial.println(" [N]"); // REPRESENT IT IN MILINEWTONS FOR MORE PRECISSION
Serial.print("momentum at the leading edge = ");
Serial.print(Mle);
Serial.println(" [Nm]");
Serial.print("position of the centre of pressure: ");
Serial.print(xcp);
Serial.println(" [mm]");
Serial.println();
Serial.println("Aerodynamic coefficients");
Serial.print("Cl = ");
Serial.println(Cl);
Serial.print("Cd = ");
Serial.println(Cd);
Serial.print("Cm = ");
Serial.println(Cm);
Serial.println();
// On serial data (any data), re-tare
if (Serial.available() > 0) {
while (Serial.available()) {
Serial.read();
tare();
Respuesta rápida
Mensaje
Verificación de la imagen
(no distingue MAYÚSC/minúsc)
  CONSULTA Luces en la tarjeta gt2560 Invitado 0 33 10-07-2020, 08:23 PM
Último mensaje: Invitado
  CONSULTA AYUDA ERROR LASERGRBL pedrovelandia 0 47 01-07-2020, 05:24 PM
Último mensaje: pedrovelandia
  CONSULTA AYUDA ERROR LASERGRBL pedrovelandia 0 38 01-07-2020, 05:23 PM
  CONSULTA AYUDA ERROR LASERGRBL pedrovelandia 0 33 01-07-2020, 05:22 PM
  CONSULTA Error compiladopara la tarjeta Arduino/Genuino Uno RobbieW21 3 403 19-04-2020, 10:55 PM
Último mensaje: JLSiles79
