[VENDO] Unidad demo de FORMBOT T-Rex2+ Dual Extruder 400x400x500 + LASER + HTExtruder
VENDO Unidad demo de la Formbot Trex2+
Solo se ha impreso 3 veces con ella
Viene con extrusor dual, unidad Laser y extrusor adicional para filamentos que requieran 300ºC
Viene con cama caliente "Keenovo" + kit SSR para instalar y controlarla por Gcode
Viene con Buildtak Removable System incluido y ya instalado!
PVPR: 2495Eur (sumando todos los extras que lleva)
La dejo por 1650€ur envio incluido a la peninsula.
[Imagen: FORMBOTTREX22_1.jpg]
+ info del fabricante:
New affordable, massive scale 3D printer. Amazing 40x40x50cm build volume.
DUAL EXTRUSION System. High Temp Extruder. LASER Engraver. GENUINE BLTouch included. LINEAR Guide.
[size=undefined][size=undefined]
T-Rex 2+ 500, Large Format Multifunctional 3D Printer
Auto bed leveling system with probe that meassures 225 points.
Delivered with:
[/size][/size]
  • High Temp Extruder
  • Dual Zone Keenovo heated bed
  • Laser engraver
[size=undefined][size=undefined][size=undefined]
Simply a great printer for more demanding user with features like:[/size]
[/size][/size]
  • Large build size 400x400x500mm
  • Independent dual extruder (IDEX): possibility of printing 2 materials at a time or 2 identical objects simultaneously.
  • Extruder wiping system: to avoid messy layers at the beginning of a 3D print, the extruders are automatically wiped.
  • Auto-leveling: no need for time-consuming manual bed leveling.
  • High-temperature extruder (included): for printing PEEK, nylon and other filaments that require high temperatures to be 3D printed.
  • Dual zone heated print bed (included): the heating is divided into 2 areas, to avoid useless heating of unused areas (a smaller portion of 200 x 200 can be heated for small objects, while the whole print bed can be heated for larger prints).
  • Laser engraver (included): capable of engraving wood, fabrics and other materials.
  • Built with high quality components
  • Stable and sturdy frame with thick linear rail and bearings
  • Industrial ball screws to ensure amazing z accuracy
T-Rex 2+ comes assembled nearly, only takes 10-15 minutes to complete assembly, very easy to operate.
Note: for better performance, we have upgraded Raptor with TBI ball screw, which will eliminate the clearance, better for auto bed leveling. meanwhile, it’ll bring more silent working environment and longer service lifespan.
 [/size]
undefined
+ info y fotos:
https://www.en3dstudios.com/product/formbot-t-rex-2-500-400x400x500mm-build-volume-dual-extruder-and-laser-engraver-3d-printer/[/size][/size]
Puede ser negociable ???
La verdad es que esta por debajo del precio de coste de todo lo que lleva....
SIGUE DISPONIBLE.
se puede recoger en mano? de donde eres?
  [vendida] Cortadora / Grabadora laser Ortu Laser Master 15w neoxM3 3 2,319 26-09-2020, 12:15 PM
Estrella [Vendida] Anycubic Kosel Linear Plus (32 bits, fliying extruder, contrapesos...) neoxM3 0 1,989 26-06-2020, 09:42 PM
  Vendo impresora 3d GEEETECH A10M DUAL COLOR zorroronoa 3 3,243 30-08-2019, 08:18 AM
Último mensaje: Kurama
  Vendo Laser diodo 15w + estructura 50*60 Forsito 3 2,901 28-08-2019, 02:30 AM
Último mensaje: diegotrap
  Vendo laser mercury pro 35w n3rull 0 1,712 10-07-2019, 01:13 PM
Último mensaje: n3rull
