[Slic3r] Configuraciones conjunta
Me gustaría que existiera un post donde se fueran subiendo configuraciones de slic3r probadas y funcionales sobretodo de gente de la conjunta porque no consigo buenos resultados.
Si pudierais indicar:
- Conjunta o en blanco.
- Hotend
- Cabezal.
- Ventilador cuerpo de Hotend: Si o No.
- Ventilador punta del Hotend: Si o No.
- Tipo de plástico y color.
Por ejemplo (la mía aunque todavía estoy probando porque tengo problemas con ella):
- Kit Conjunta.
- Hotend:J-Head
- Punta: 0.5
- Ventilador cuerpo del Hotend: Si
- Ventilador punta del Hotend: No
- Plástico: ABS Negro
# generated by Slic3r 0.9.10b on Tue Sep 17 00:03:44 2013
avoid_crossing_perimeters = 0
bed_size = 189,194
bed_temperature = 90
bottom_solid_layers = 3
bridge_acceleration = 0
bridge_fan_speed = 100
bridge_flow_ratio = 1
bridge_speed = 60
brim_width = 0
complete_objects = 0
cooling = 1
default_acceleration = 0
disable_fan_first_layers = 0
duplicate = 1
duplicate_distance = 6
duplicate_grid = 1,1
end_gcode = M104 S0 ; turn off temperature\nM140 S0 ;Hotbed turn off\nG28 X0  ; home X axis\nG90; Coordenadas absolutas\nG0 Y200; Sacar bandeja\nM84     ; disable motors
external_perimeter_speed = 70%
external_perimeters_first = 0
extra_perimeters = 1
extruder_clearance_height = 20
extruder_clearance_radius = 20
extruder_offset = 0x0
extrusion_axis = E
extrusion_multiplier = 0.94
extrusion_width = 0
fan_always_on = 1
fan_below_layer_time = 60
filament_diameter = 2.90
fill_angle = 45
fill_density = 0.3
fill_pattern = honeycomb
first_layer_bed_temperature = 90
first_layer_extrusion_width = 200%
first_layer_height = 0.4
first_layer_speed = 30%
first_layer_temperature = 250
g0 = 0
gap_fill_speed = 20
gcode_arcs = 0
gcode_comments = 0
gcode_flavor = reprap
infill_acceleration = 0
infill_every_layers = 1
infill_extruder = 1
infill_extrusion_width = 0
infill_first = 0
infill_only_where_needed =
infill_speed = 60
layer_gcode =
layer_height = 0.4
max_fan_speed = 100
min_fan_speed = 100
min_print_speed = 25
min_skirt_length = 0
notes =
nozzle_diameter = 0.5
only_retract_when_crossing_perimeters = 1
output_filename_format = [input_filename_base].gcode
perimeter_acceleration = 0
perimeter_extruder = 1
perimeter_extrusion_width = 0
perimeter_speed = 30
perimeters = 3
post_process =
print_center = 100,100
raft_layers = 0
randomize_start = 0
resolution = 0
retract_before_travel = 1.0
retract_layer_change = 1
retract_length = 2
retract_length_toolchange = 10
retract_lift = 0
retract_restart_extra = 0
retract_restart_extra_toolchange = 0
retract_speed = 25
rotate = 0
scale = 1
skirt_distance = 6
skirt_height = 1
skirts = 1
slowdown_below_layer_time = 10
small_perimeter_speed = 30
solid_fill_pattern = rectilinear
solid_infill_below_area = 70
solid_infill_every_layers = 0
solid_infill_extrusion_width = 0
solid_infill_speed = 60
spiral_vase = 0
start_gcode = G28 ; home all axes
support_material = 0
support_material_angle = 0
support_material_enforce_layers = 0
support_material_extruder = 1
support_material_extrusion_width = 0
support_material_interface_layers = 0
support_material_interface_spacing = 0
support_material_pattern = rectilinear
support_material_spacing = 2.5
support_material_speed = 60
support_material_threshold = 0
temperature = 250
threads = 2
toolchange_gcode =
top_infill_extrusion_width = 0
top_solid_infill_speed = 50
top_solid_layers = 3
travel_speed = 130
use_relative_e_distances = 0
vibration_limit = 0
wipe = 0
z_offset = 0
*Actualizado a 18 de Septiembre de 2013, voy poniendo la que mejores resultados me va dando.
Muy interesante, sobre todo que ponga las configuraciones lo que han conseguido imprimir muy muy bien, para comparar y etc, yo le he puesto hoy la boquilla de 0.35 y ahí estoy peleándome.
Todavía no la he empezado a montar, pero agradecería tener unas configuraciones optimas para empezar a calibrar con resultados.
Para imprimir piezas grandes o estrechas y que no se separen las capas. esta pensado para que eche mas plastico en perimetros y relleno y de esta manera se mitigue la contraccion del material
# generated by Slic3r 0.9.10b on Fri Sep 20 23:26:13 2013
bed_size = 200,200
bottom_solid_layers = 2
bridge_flow_ratio = 0.80
bridge_speed = 60
brim_width = 0
complete_objects =
cooling =
duplicate = 1
end_gcode = M104 S0 ; turn off temperature\nG28 X0  ; home X axis\nM84     ; disable motors
external_perimeter_speed = 50%
extrusion_axis = E
extrusion_width = 0.5
fan_always_on =
fill_angle = 45
fill_density = 0.7
first_layer_height = 0.2
first_layer_speed = 60%
g0 = 0
gap_fill_speed = 25
gcode_arcs = 0
gcode_comments = 0
infill_extruder = 1
infill_first = 0
infill_only_where_needed = 0
infill_speed = 50
layer_gcode =
layer_height = 0.3
max_fan_speed = 100
min_fan_speed = 100
notes =
perimeters = 3
post_process =
raft_layers = 0
randomize_start = 1
resolution = 0
retract_before_travel = 2.0
retract_length = 1.5
retract_lift = 0
retract_speed = 60
rotate = 0
scale = 1
skirt_distance = 5
skirt_height = 1
skirts = 1
small_perimeter_speed = 45
spiral_vase = 0
support_material =
support_material_speed = 50
temperature = 250
threads = 2
toolchange_gcode =
top_infill_extrusion_width = 110%
top_solid_layers = 2
travel_speed = 70
vibration_limit = 0
wipe = 0
z_offset = 0
Alguna configuración con 0.35 que vaya bien? para comparar, por que no doy con el punto.
lo unico que tienes que cambiar es el Default extrusion width y nozzle diameter por 0.35
Pregunta de novato: ¿donde esta el archivo de configuración del slic3r para poder editarlo?
EDITO: ya lo encontré: pestaña de slic3r, configurar, file, load config.
muy buen post, a ver si me sirve para algo.. porque para piezas grandes con paredes estrechas, me sigue fallando la separación entre capas.
  CONSULTA mi ramps 1.4 EEB no reconoce configuraciones para doble extrusor con un solo nozzle. erjavi_zgz 9 2,667 29-11-2021, 01:41 PM
  duda configuraciones bowden vs directa fruns 1 1,275 21-04-2020, 02:59 PM
Último mensaje: Jainglis
  Perdí las configuraciones de movimiento - Ender 3 Pro Sr. Kowi 4 5,473 23-09-2019, 01:21 AM
Último mensaje: Sr. Kowi
  Las piezas salen a espejo en Cura y Slic3r PacoMB 6 5,761 12-02-2019, 10:11 AM
Último mensaje: PacoMB
  CONSULTA Soportes en slic3r JaumeS 0 1,946 28-06-2018, 11:46 PM
Último mensaje: JaumeS
