CONSULTA error al compilar exit status1 error al compilar tarjeta arduino uno
no he podido compilarlo , desde ya muchas gracias por su tiempo
#include <LiquidCrystal.h>  // includes the LiquidCrystal Library
#include <math.h>    //para el redondeo
LiquidCrystal lcd(2, 3, 4, 5, 6, 7);  // Creates an LCD object. Parameters: (rs, enable, d4, d5, d6, d7)
// Connect panel using the standard lines.
// Sensor 1, trigger pin 13 y echo pin 12.
const int trigPin1 = 13;
const int echoPin1 = 12;
// Sensor 2, trigger pin 11 y echo pin 10.
const int trigPin2 = 11;
const int echoPin2 = 10;
// dimensiones Tanque 1 (el que esta en la parte inferior) en metros.
const float lengthBottomTankM = 3.2;
const float widthBottomTankM = 2;
const float deepBottomTankM = 1.7;
const float volTotalBottomTankM3 = 8.96;    // Restado 0.3 de distancia al sensor tanque inferior
// dimensiones Tanque 2 (el que esta en la parte inferior) en mestros
const float lengthUpTankM = 2.74;
const float widthUpTankM = 2;
const float deepUpTankM = 1.9;
const float volTotalUpTankM3 = 9.32;    // Restado 0.2 de distancia al sensor tanque superior
long duration1;
float deepBottomTankCm;
long duration2;
float deepUpTankCm;
float volumeBottomTank;
float volumeUpTank;
float porcBottomTank;
float porcUpTank;
void setup() {
  lcd.begin(16,2);  // Initializes the interface to the LCD screen, and specifies the dimensions (width and height) of the display
  pinMode(trigPin1, OUTPUT);
  pinMode(echoPin1, INPUT);
  pinMode(trigPin2, OUTPUT);
  pinMode(echoPin2, INPUT);
  Serial.begin (9600);
void loop() {
// Trigger Lower tank
  digitalWrite(trigPin1, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin1, HIGH);
  delayMicroseconds(10);
  duration1 = pulseIn(echoPin1, HIGH);
  deepBottomTankCm= duration1*0.034/2;
// Trigger upper tank
  digitalWrite(trigPin2, LOW);
  digitalWrite(trigPin2, HIGH);
  duration2 = pulseIn(echoPin2, HIGH);
  deepUpTankCm= duration2*0.034/2;
if (deepBottomTankCm > 0 && deepUpTankCm > 0) {
// Make calculations based on volume1 and volume2
  volumeBottomTank = lengthBottomTankM * widthBottomTankM * (deepBottomTankM - (float)deepBottomTankCm/100);
  porcBottomTank = (float)volumeBottomTank/(float)volTotalBottomTankM3 * 100;
  volumeBottomTank = round(volumeBottomTank*10);
  volumeBottomTank = volumeBottomTank/10;
  volumeUpTank = lengthUpTankM * widthUpTankM * (deepUpTankM - (float)deepUpTankCm/100);
  volumeUpTank = round(volumeUpTank*10);
  volumeUpTank = volumeUpTank/10;
  porcUpTank = (float)volumeUpTank / volTotalUpTankM3 * 100;
  Serial.println("cmBottom," + String(deepBottomTankCm) + ";
  cmUp," + String(deepUpTankCm));
// Show information on LCD
  lcd.setCursor(0,0);  // Sets the location at which subsequent text written to the LCD will be displayed
  lcd.println("S: " + String(volumeUpTank) + "m3, "+ String(round(porcUpTank)) + "%      ");  // Prints string "Distance" on the LCD
  lcd.println("DistaCm: " + String(deepUpTankCm) + "      ");
  delay(10);
  lcd.setCursor(0,1);
  lcd.println("I: " + String(volumeBottomTank) + "m3, "+ String(round(porcBottomTank)) + "%      ");
  lcd.println("DistCm: " + String(deepBottomTankCm) + "          ");
  delay(500);
Si además del código incluyes el error que te tira el IDE será más probable que alguien se lo mire.
Buenos días
El problema lo tienes en tus líneas 81 y 82
Esas líneas las has copiado mal, y la primera línea le has puesto los dos puntos para cerrarla, pero la orden esta a medias, la orden correcta es
    Serial.println("cmBottom," + String(deepBottomTankCm) + "cmUp," + String(deepUpTankCm));
Y así si compila
Tu código parece estar bastante bien estructurado, pero hay algunos puntos a revisar y corregir para asegurar que compile y funcione correctamente. Aquí te dejo algunas sugerencias y correcciones:
  1. Errores en el Código:
    • Cadena de texto sin cerrar: Hay una cadena de texto en
      Serial.println
      que no está cerrada correctamente.
    • Fórmula de redondeo: La fórmula para redondear el volumen está bien, pero podrías simplificarla utilizando
      round()
      directamente.
  2. Corregir el Error de Compilación:
    • Errores de Sintaxis en
      Serial.println
      : La cadena que estás imprimiendo en el monitor serie tiene un error de sintaxis.
    • Fórmulas para el Volumen: Asegúrate de que la fórmula para el volumen y los porcentajes esté correcta.
Aquí tienes el código corregido:
// dimensiones Tanque 2 (el que esta en la parte superior) en metros
long duration1;
long duration2;
float deepUpTankCm;
float volumeUpTank;
float porcUpTank;
void setup() {
void loop() {
  deepBottomTankCm = duration1 * 0.034 / 2;
  // Trigger Upper tank
  deepUpTankCm = duration2 * 0.034 / 2;
    volumeBottomTank = lengthBottomTankM * widthBottomTankM * (deepBottomTankM - deepBottomTankCm / 100);
    porcBottomTank = (volumeBottomTank / volTotalBottomTankM3) * 100;
    volumeBottomTank = round(volumeBottomTank * 10) / 10;
    volumeUpTank = lengthUpTankM * widthUpTankM * (deepUpTankM - deepUpTankCm / 100);
    volumeUpTank = round(volumeUpTank * 10) / 10;
    porcUpTank = (volumeUpTank / volTotalUpTankM3) * 100;
    Serial.println("cmBottom: " + String(deepBottomTankCm) + " cm, cmUp: " + String(deepUpTankCm) + " cm");
    lcd.setCursor(0,0);
    lcd.print("S: " + String(volumeUpTank) + "m3, " + String(round(porcUpTank)) + "%");
    lcd.setCursor(0,1);
    lcd.print("D: " + String(volumeBottomTank) + "m3, " + String(round(porcBottomTank)) + "%");
  delay(500);  // Reduced delay for smoother updates
Notas Importantes:
  • Serial.println
    : Asegúrate de cerrar correctamente las cadenas de texto.
  • Escala del Volumen: Asegúrate de que las fórmulas para el cálculo del volumen y el porcentaje sean correctas según la geometría del tanque.
  • Retraso: Puedes ajustar el
    delay()
    según la necesidad de actualización en tu pantalla LCD.
Prueba el código corregido y verifica si compila y funciona como esperas. ¡Buena suerte con tu proyecto!
  tarjeta creality silenciosa pipeferr 2 1,938 27-12-2024, 10:11 PM
Último mensaje: pipeferr
  DUDA Envío de datos. Tarjeta feather 32u4 Okene 4 2,418 29-07-2024, 10:17 PM
Último mensaje: Hectormonero
  Fusionar dos sketch en uno (código arduino) jgarridc 22 16,961 31-12-2018, 07:37 PM
Último mensaje: Surbyte
Pregunta [SOL] Tengo dos URL's en el mismo servidor en wordpress como redirigir de uno a otro Electromecánico 5 4,231 02-03-2018, 12:04 PM
  Problemas tarjeta de red Electromecánico 4 3,132 17-04-2015, 12:33 PM
Último mensaje: jumasape
