Robot con servos y ultrasonido
Buenas. Estoy tratando de montar un robot con dos servos y un ultrasonido. Es mantisWalkerUltrasonicMk2.ino
El sketch lo compila bien, pero me da problemas al subirlo a arduino nano. Es el siguiente
#define STEP_DELAY 160
#define STOP_DISTANCE 10  //stop distance in cm
#include <Servo.h>
#include <NewPing.h>
//format: front leg position, back leg position
char walkingForward[] = {SERVO_BACK_DISTANCE, SERVO_FORWARD_DISTANCE,
                        SERVO_FORWARD_DISTANCE, SERVO_FORWARD_DISTANCE,
                        SERVO_FORWARD_DISTANCE, SERVO_BACK_DISTANCE,
                        SERVO_BACK_DISTANCE, SERVO_BACK_DISTANCE
NewPing sonarEyes(TRIGGER_PIN, ECHO_PIN, MAXIMUM_DISTANCE);
Servo servoBackLegs, servoFrontLegs;
void setup() {
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, HIGH);
  //setup Pins to connect Servos To
  pinMode(BACK_LEGS_GND, OUTPUT);  //tie pin 8 to GND
  digitalWrite(BACK_LEGS_GND, LOW);
  pinMode(BACK_LEGS_VCC, OUTPUT);  //tie pin 9 to VCC
  digitalWrite(BACK_LEGS_VCC,HIGH);
  servoBackLegs.attach(BACK_LEGS_PIN);
  pinMode(FRONT_LEGS_VCC, OUTPUT);  //tie pin 2 to VCC
  digitalWrite(FRONT_LEGS_VCC, HIGH);
  servoFrontLegs.attach(FRONT_LEGS_PIN);
  servoBackLegs.write(SERVO_CENTRED);
  servoFrontLegs.write(SERVO_CENTRED);
  //setup Pins for Ultrasonic Sensor
  pinMode(US_GND, OUTPUT);
  digitalWrite(US_GND, LOW);
  pinMode(US_VCC, OUTPUT);
  digitalWrite(US_VCC,HIGH);
  delay(2000);
  digitalWrite(LED_BUILTIN, LOW); //turn off built in LED
void loop() {
  // put your main code here, to run repeatedly:
  while (checkForObstruction()) {  //returns true if obstruction, otherwise skip this loop
    digitalWrite(LED_BUILTIN, HIGH);  //turn on LED for visual indication of obstruction
    //step back and turn
    delay(2000);
    walkBackAndTurnLeft();
    digitalWrite(LED_BUILTIN, LOW);  //turn back off again
  stepForward();
void stepForward() {
  for (int n = 0; n < 4; n++) {
    servoFrontLegs.write(walkingForward[n * 2]);
    servoBackLegs.write(walkingForward[(n * 2) + 1]);
    delay(STEP_DELAY);
void walkBackAndTurnLeft()  {
  for (int n = 0; n < 14; n++) {
    servoBackLegs.write(SERVO_BACK_DISTANCE - 40);
    delay(200);
    servoFrontLegs.write(SERVO_FORWARD_DISTANCE);
    servoBackLegs.write(SERVO_FORWARD_DISTANCE + 20);
    delay(300);
  delay(300);
bool checkForObstruction() {
  int distance = sonarEyes.ping_cm();
  if (distance <= STOP_DISTANCE && distance != 0) {
    return true;
  } else {
    return false;
El mensaje de error es Arduino:1.8.12 (Linux), Tarjeta:"Arduino Nano, ATmega328P"
El Sketch usa 3052 bytes (9%) del espacio de almacenamiento de programa. El máximo es 30720 bytes.
Las variables Globales usan 83 bytes (4%) de la memoria dinámica, dejando 1965 bytes para las variables locales. El máximo es 2048 bytes.
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Problema subiendo a la placa. Visita http://www.arduino.cc/en/Guide/Troubleshooting#upload para sugerencias.
Este informe podría contener más información con
"Mostrar salida detallada durante la compilación"
opción habilitada en Archivo -> Preferencias.
Alguien puede ayudarme ?.
Buenos días.
En Linux no puedo ayudarte, pero supongo que el IDE funcionará de una manera parecida.
Con este mensaje de error, parece que el problema es que el IDE no puede comunicarse con el Arduino NANO, comprueba en la pestaña del IDE llamada "Herramientas", "placa", que tengas seleccionado "Arduino Nano", si no lo tienes seleccionado, tendrás que cambiar la placa que tengas seleccionada por el Arduino Nano.
De todas formas a mi me da otro error de compilación, dice que no están declarados todo lo que pones en estas líneas
porque no has declarado el objeto servo, ni las funciones que tiene que realizar, has copiado mal el programa, lo extraño es que a ti si te compila. Pero yo trabajo con Windows y tu trabajas con Linux.
Buenos días.
Perdón por la tardanza. El problema estaba en la placa compatible. Funciona, aunque en vez de parar vuelca
Muchas gracias
Gracias por la información!
Aprende a invertir en criptos, fórex o materias primas con este bróker https://roboforex.com/es/beginners/info/...ex/gbpcad/ que ya lleva mucho tiempo en el mercado.
Buenas tardes.
Me alegro que ya funcione, un saludo.
  Robot niños Robomaker Clementoni Pau Bassets 0 575 04-06-2020, 12:24 PM
Último mensaje: Pau Bassets
Dedo arriba Global Robot Expo Madrid samuelb 11 3,850 04-03-2016, 03:05 PM
Último mensaje: Milay
