Alguien me podría ayudar con este proyecto
Buenos días a todos,
Era para preguntaros que falla en este código, ya que levo semanas intentándolo arreglar pero sin éxito, seria de gran ayuda decirme que falla.
Muchas Gracias
A qui tenéis el Código:
// Temperatura
#include <OneWire.h>
#include <LiquidCrystal.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 9
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
float tempC = 0;
float tempF = 0;
LiquidCrystal lcd(2, 3, 4, 5, 6, 7);;
// PHSENSOR
#include "ph_grav.h"                                  //header file for Atlas Scientific gravity pH sensor
#include "LiquidCrystal.h"                            //header file for liquid crystal display (lcd)
String inputstring = "";                              //a string to hold incoming data from the PC
boolean input_string_complete = false;                //a flag to indicate have we received all the data from the PC
char inputstring_array[10];                          //a char array needed for string parsing
Gravity_pH pH = A0;                                  //assign analog pin A0 of Arduino to class Gravity_pH. connect output of pH sensor to pin A0
LiquidCrystal pH_lcd(2, 3, 4, 5, 6, 7);              //make a variable pH_lcd and assign arduino digital pins to lcd pins (2 -> RS, 3 -> E, 4 to 7 -> D4 to D7)
void setup()
  // Temperatura
    sensors.begin();
    lcd.begin(16, 2);
    lcd.clear();
    pinMode(3, OUTPUT);
    analogWrite(3, 0);
    Serial.begin(9600);
  // PHSENSOR
    Serial.begin(9600);                                //enable serial port
    pH_lcd.begin(16, 2);                                //start lcd interface and define lcd size (20 columns and 4 rows)
    pH_lcd.setCursor(0, 2);                            //place cursor on screen at column 1, row 4
    pH_lcd.print("--------------------");              //display characters
    pH_lcd.setCursor(5, 1);                            //place cursor on screen at column 6, row 2
    pH_lcd.print("pH ");                        //display "pH Reading"
    if (pH.begin()) {
      Serial.println("Loaded EEPROM");
    Serial.println(F("Use commands \"CAL,4\", \"CAL,7\", and \"CAL,10\" to calibrate the circuit to those respective values"));
    Serial.println(F("Use command \"CAL,CLEAR\" to clear the calibration"));
    void serialEvent() {                                  //if the hardware serial port_0 receives a char
  inputstring = Serial.readStringUntil(13);          //read the string until we see a <CR>
  input_string_complete = true;                      //set the flag used to tell if we have received a completed string from the PC
  void loop()
  // Temperatura
  sensors.requestTemperatures();
  tempC = sensors.getTempCByIndex(0);
  tempF = sensors.toFahrenheit(tempC);
  delay(1000);
  Serial.println(tempC);
  lcd.setCursor(0, 0);
  lcd.print(" grados: ");
  lcd.print(tempC);
  lcd.setCursor(0, 1);
  // PHSENSOR
  if (input_string_complete == true) {                //check if data received
    inputstring.toCharArray(inputstring_array, 30);  //convert the string to a char array
    parse_cmd(inputstring_array);                    //send data to pars_cmd function
    input_string_complete = false;                    //reset the flag used to tell if we have received a completed string from the PC
    inputstring = "";                                //clear the string
  Serial.println(pH.read_ph());                      //output pH reading to serial monitor
  pH_lcd.setCursor(8, 2);                            //place cursor on screen at column 9, row 3
  pH_lcd.print(pH.read_ph());                        //output pH to lcd
  delay(1000);
void parse_cmd(char* string) //For calling calibration functions
strupr(string);                                  //convert input string to uppercase
if (strcmp(string, "CAL,4") == 0) {              //compare user input string with CAL,4 and if they match, proceed
  pH.cal_low();                                  //call function for low point calibration
  Serial.println("LOW CALIBRATED");
else if (strcmp(string, "CAL,7") == 0) {          //compare user input string with CAL,7 and if they match, proceed
  pH.cal_mid();                                  //call function for midpoint calibration
  Serial.println("MID CALIBRATED");
else if (strcmp(string, "CAL,10") == 0) {        //compare user input string with CAL,10 and if they match, proceed
  pH.cal_high();                                  //call function for highpoint calibration
  Serial.println("HIGH CALIBRATED");
else if (strcmp(string, "CAL,CLEAR") == 0) {      //compare user input string with CAL,CLEAR and if they match, proceed
  pH.cal_clear();                                //call function for clearing calibration
  Serial.println("CALIBRATION CLEARED");
Buenas noches.
He unido o juntado los dos códigos en uno solo y me compila sin problemas, utilizando como base tus dos programas copiados.
Si has leído la respuesta que te puse en la otra publicación, veras que juntar dos códigos no es tan difícil, lo acabo de hacer en 10 minutos, porque no conocía los sensores ni las librerías, y eso me ha llevado mas tiempo.
Voy a hacer algo que no me gusta, y es pasarte el código, prefiero que cada cual aprenda a su manera y con la información mas que suficiente que pueda encontrar.
Me debes una cerveza
float tempC = 0;
float tempF = 0;
void setup() {
  if (pH.begin()) {
  sensors.begin();
  lcd.begin(16, 2);
  lcd.clear();
  pinMode(3, OUTPUT);
  analogWrite(3, 0);
  Serial.begin(9600);
void loop()
  loop_temp();
  loop_ph();
void loop_temp() {
  delay(1000);
  lcd.print(tempC);
void loop_ph() {
  delay(1000);
void parse_cmd(char* string) {                      //For calling calibration functions
  Cómo se programa este Arduino? cybero 7 5,139 02-01-2017, 06:41 PM
Último mensaje: daniez
  Proyecto tablet pc con arduino crivi01 3 3,112 23-10-2015, 08:13 PM
Último mensaje: jukillo
  Piedra, papel y tijera con bluetooth (Proyecto Arduino) Asclem 0 2,251 14-07-2015, 06:24 PM
Último mensaje: Asclem
  Proyecto alimentar 66 leds con Arduino Nano Electromecánico 2 3,132 19-03-2015, 01:31 PM
Último mensaje: sifou
  ayuda con proyecto del garduino wuasichu 15 6,914 10-09-2014, 07:51 AM
Último mensaje: wuasichu
