CONSULTA Problema con eje z: Return to zero
Pregunta
Hola, como están todos?
Bueno les comento mi problema. No importa donde le indique el ZERO del eje Z, siempre que haga clic en el botón Return to home el eje Z se va a arriba del todo llegando a su limite físico/mecanico y no deja de funcionar hasta 3 segundos despues de estar golpeando el limite.
Software:
Universal Gcode Plataform (Version 2.0 [nightly])
Configuración gcode:
**** Connected to COM8 @ 115200 baud ****
Grbl 1.1h ['$' for help]
$0 = 10    (Step pulse time, microseconds)
$1 = 25    (Step idle delay, milliseconds)
$2 = 0    (Step pulse invert, mask)
$3 = 5    (Step direction invert, mask)
$4 = 0    (Invert step enable pin, boolean)
$5 = 0    (Invert limit pins, boolean)
$6 = 0    (Invert probe pin, boolean)
$10 = 1    (Status report options, mask)
$11 = 0.010    (Junction deviation, millimeters)
$12 = 0.002    (Arc tolerance, millimeters)
$13 = 1    (Report in inches, boolean)
$20 = 0    (Soft limits enable, boolean)
$21 = 0    (Hard limits enable, boolean)
$22 = 0    (Homing cycle enable, boolean)
$23 = 0    (Homing direction invert, mask)
$24 = 400.000    (Homing locate feed rate, mm/min)
$25 = 600.000    (Homing search seek rate, mm/min)
$26 = 250    (Homing switch debounce delay, milliseconds)
$27 = 0.000    (Homing switch pull-off distance, millimeters)
$30 = 1000    (Maximum spindle speed, RPM)
$31 = 0    (Minimum spindle speed, RPM)
$32 = 0    (Laser-mode enable, boolean)
$100 = 250.000    (X-axis travel resolution, step/mm)
$101 = 250.000    (Y-axis travel resolution, step/mm)
$102 = 250.000    (Z-axis travel resolution, step/mm)
$110 = 200.000    (X-axis maximum rate, mm/min)
$111 = 200.000    (Y-axis maximum rate, mm/min)
$112 = 200.000    (Z-axis maximum rate, mm/min)
$120 = 10.000    (X-axis acceleration, mm/sec^2)
$121 = 200.000    (Y-axis acceleration, mm/sec^2)
$122 = 10.000    (Z-axis acceleration, mm/sec^2)
$130 = 200.000    (X-axis maximum travel, millimeters)
$131 = 100.000    (Y-axis maximum travel, millimeters)
$132 = 200.000    (Z-axis maximum travel, millimeters)
Lo mas extraño es que con la versiones de Universal Gcode Sender v2.0 [nightly] funciona perfecto el botón Return to home!
Los ejes X e Y funcionan perfecto.
Que será?
Entiendo que no tienes final de carrera? Correcto?
(24-09-2020, 08:02 AM)tagmindb2f escribió: Entiendo que no tienes final de carrera? Correcto?
Exacto, no tengo final de carrera.
  Problema con el eje z xan 10 7,850 27-12-2020, 08:56 PM
Último mensaje: xan
