Si caliento el hotend y le doy a estruir el motor funciona es cuando cargo algún objeto y le doy a imprimir la cama se pone 90 el hotend 260 y empieza a imprimir pero el motor del extrusor no se mueve
Imprime en vacio
19:39:45.237 : Printer reset detected - initalizing
19:39:45.237 : start
19:39:45.237 : echo:Marlin 1.1.8
19:39:45.242 : echo: Last Updated: 2017-12-25 12:00 | Author: cocopunks
19:39:45.245 : echo:Compiled: Aug 9 2018
19:39:45.249 : echo: Free Memory: 3210 PlannerBufferBytes: 1232
19:39:45.261 : echo:V47 stored settings retrieved (614 bytes; crc 42365)
19:39:45.264 : echo: G21 ; Units in mm
19:39:45.267 : echo: M149 C ; Units in Celsius
19:39:45.269 : echo:Filament settings: Disabled
19:39:45.272 : echo: M200 D1.75
19:39:45.272 : echo: M200 D0
19:39:45.275 : echo:Steps per unit:
19:39:45.277 : echo: M92 X160.00 Y160.00 Z800.00 E109.87
19:39:45.280 : echo:Maximum feedrates (units/s):
19:39:45.285 : echo: M203 X300.00 Y300.00 Z5.00 E25.00
19:39:45.288 : echo:Maximum Acceleration (units/s2):
19:39:45.291 : echo: M201 X2000 Y2000 Z100 E10000
19:39:45.296 : echo:Acceleration (units/s2): P<print_accel> R<retract_accel> T<travel_accel>
19:39:45.302 : echo: M204 P1500.00 R10000.00 T1500.00
19:39:45.310 : echo:Advanced: S<min_feedrate> T<min_travel_feedrate> B<min_segment_time_us> X<max_xy_jerk> Z<max_z_jerk> E<max_e_jerk>
19:39:45.315 : echo: M205 S0.00 T0.00 B20000 X10.00 Y10.00 Z0.30 E5.00
19:39:45.318 : echo:Home offset:
19:39:45.321 : echo: M206 X0.00 Y0.00 Z-1.00
19:39:45.321 : echo:Auto Bed Leveling:
19:39:45.323 : echo: M420 S0 Z0.00
19:39:45.326 : echo:Material heatup parameters:
19:39:45.329 : echo: M145 S0 H180 B70 F0
19:39:45.332 : echo: M145 S1 H240 B110 F0
19:39:45.332 : echo
![Lengua Lengua](https://www.spainlabs.com/foros/images/smilies/tongue.png)
ID settings:
19:39:45.334 : echo: M301 P12.16 I0.82 D45.32
19:39:45.340 : echo: M304 P230.35 I19.66 D674.62
19:39:45.340 : echo:Z-Probe Offset (mm):
19:39:45.342 : echo: M851 Z-1.35
19:39:48.388 : echo:SD card ok
19:39:48.417 : FIRMWARE_NAME:Marlin 1.1.8 (Github) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:CocoCubo EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
19:39:48.417 : Cap:SERIAL_XON_XOFF:0
19:39:48.419 : Cap:EEPROM:1
19:39:48.420 : Cap:VOLUMETRIC:1
19:39:48.422 : Cap:AUTOREPORT_TEMP:1
19:39:48.422 : Cap
ROGRESS:0
19:39:48.425 : Cap
RINT_JOB:1
19:39:48.425 : Cap:AUTOLEVEL:1
19:39:48.427 : Cap:Z_PROBE:1
19:39:48.427 : Cap:LEVELING_DATA:1
19:39:48.430 : Cap:BUILD_PERCENT:0
19:39:48.433 : Cap:SOFTWARE_POWER:0
19:39:48.433 : Cap:TOGGLE_LIGHTS:0
19:39:48.436 : Cap:CASE_LIGHT_BRIGHTNESS:0
19:39:48.438 : Cap:EMERGENCY_PARSER:0
19:39:48.481 : X:0.00 Y:0.00 Z:-2.00 E:0.00 Count A:0 B:0 Z:-800
19:39:48.497 : echo
![Gran sonrisa Gran sonrisa](https://www.spainlabs.com/foros/images/smilies/biggrin.png)
EBUG:INFO,ERRORS
19:39:48.499 : echo:Active Extruder: 0
19:39:48.501 : Begin file list
19:39:48.510 : CUBO-D~1.GCO 27251107
19:39:48.528 : End file list
19:39:48.528 : Begin file list
19:39:48.528 : CUBO-D~1.GCO 27251107
19:39:48.528 : echo
EBUG:INFO,ERRORS
19:39:48.528 : echo:Active Extruder: 0
