DUDA Problema el subir Marlín 2.0 a Anet con marlín 1.1.9.1
Hola estoy intentando actualizar la placa de mi anet con marlín 1.1.9.1 a  Marlín 2.0 con Visual Studio Code y me da fallo al subirlo. El vídeo que he seguido es ese:
[video=youtube] https://www.youtube.com/watch?v=RhfnzML02bw&t=1s[/video]
Windows PowerShell
Copyright (C) Microsoft Corporation. Todos los derechos reservados.
Prueba la nueva tecnología PowerShell multiplataforma https://aka.ms/pscore6
PS C:\Users\samue\OneDrive\Escritorio\Instalar Marlin\Marlin-2.0.x> platformio run --target upload -e sanguino1284p
Processing sanguino1284p (platform: atmelavr; board: sanguino_atmega1284p; framework: arduino)
---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/sanguino_atmega1284p.html
PLATFORM: Atmel AVR (2.2.0) > Sanguino ATmega1284p (16MHz)
HARDWARE: ATMEGA1284P 16MHz, 16KB RAM, 124KB Flash
DEBUG: Current (simavr) On-board (simavr)
PACKAGES:
- framework-arduino-avr 5.0.0
- tool-avrdude 1.60300.200527 (6.3.0)
- toolchain-atmelavr 1.50400.190710 (5.4.0)
Converting Marlin.ino
LDF: Library Dependency Finder -> http://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 6 compatible libraries
Scanning dependencies...
Dependency Graph
|-- <LiquidCrystal> 1.5.0
|   |-- <Wire> 1.0
|-- <Wire> 1.0
|-- <SPI> 1.0
|-- <EEPROM> 2.0
|-- <SoftwareSerial> 1.0
Building in release mode
Checking size .pio\build\sanguino1284p\firmware.elf
Advanced Memory Usage is available via "PlatformIO Home > Project Inspect"
RAM:   [==        ]  25.0% (used 4096 bytes from 16384 bytes)
Flash: [========= ]  88.1% (used 111894 bytes from 126976 bytes)
Configuring upload protocol...
AVAILABLE: arduino
CURRENT: upload_protocol = arduino
Looking for upload port...
Auto-detected: COM4
Uploading .pio\build\sanguino1284p\firmware.hex
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x73
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x74
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x74
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x0a
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x65
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x63
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x68
avrdude done.  Thank you.
*** [upload] Error 1
================================================================================================== [FAILED] Took 58.08 seconds ==================================================================================================
Environment    Status    Duration
sanguino1284p  FAILED    00:00:58.078
============================================================================================= 1 failed, 0 succeeded in 00:00:58.078 =============================================================================================PS C:\Users\samue\OneDrive\Escritorio\Instalar Marlin\Marlin-2.0.x> echo "done" >C:\Users\samue\AppData\Local\Temp\ipc
Hola, el problema que estás teniendo se debe a que el AVRdude no se está comunicando correctamente con la placa.
Esto puede deberse a varias causas: que la placa no tenga bootloader, que la velocidad de conexión no sea la adecuada, que el puerto que se está detectando de forma automática (COM4) no sea el que tiene asignado la placa o que el puerto sea correcto, pero esté bloqueado por otra aplicación.
Cierra cualquier aplicación que se utilice para comunicar con la impresora y comprueba en el administrador de dispositivos que la placa está conectada en ese puerto.
Las otras dos causas parecen más improbables.
HOLA YO TENGO EL MISMO PROBLEMA Y EL PUERTO SI ES EL INDICADO
es mas puedo usar la impresora desde la computadora si se esta detectando bien y siguiendo el consejo de arriba cerré todos los programas y me sigue apareciendo el error
incluso reinicie la computadora y volví a compilar lo único que abrí después de reiniciar fue el vs code
Hola, si con PlatformIO y VSC se tiene el error que indicaba el autor del post, teniendo bien conectada la placa al ordenador (driver correctamente instalado y puerto COM asignado), entonces es que no hay nadie al otro lado del cable USB para contestar al AVRdude y ese tiene que ser el bootloader.
Que puedas conectar la impresora y controlarla desde el ordenador solo indica que la placa tiene un firmware instalado y funcionando, pero para cambiarlo utilizando la conexión USB tiene que haber un bootloader también en ella o no se conectarán los dos dispositivos (ordenador y placa): en caso de no tenerlo, tendrás que instalarlo si quieres utilizar la conexión USB para cambiar el firmware.
Échale un ojo a este post donde explico este tema.
muchas gracias por tu respuesta
Sisi1
(12-01-2021, 11:38 AM)Simemart escribió: Hola, si con PlatformIO y VSC se tiene el error que indicaba el autor del post, teniendo bien conectada la placa al ordenador (driver correctamente instalado y puerto COM asignado), entonces es que no hay nadie al otro lado del cable USB para contestar al AVRdude y ese tiene que ser el bootloader.
Video APORTE INSTALAR MARLIN EN ANET A8 PLUS CON OPCIÓN NIVELADO CAMA kuadri 18 5,806 15-12-2022, 11:59 PM
  placa anet v1.7 no me deja subir el firmware Hunterfett 4 2,133 19-09-2022, 02:12 PM
  CONSULTA ANET A8 CON RAMPS 1.4 CONFIG MARLIN Mekruh27 4 1,925 27-10-2020, 09:38 PM
Último mensaje: Mekruh27
  Anet a8, problema tras problema tras problema art_Vader 5 1,653 22-03-2020, 05:50 PM
Último mensaje: art_Vader
  DUDA Problema al activar EEPROM anet e10 marlin Jesusev 4 2,845 13-01-2018, 08:51 PM
Último mensaje: Jesusev
