DUDA Eleksmaker A3 Pro
Buenas tardes a todos/as, tengo una CNC Láser eleksmaker a3 Pro la cual tiene un láser de 15W y le he adaptado un taladro para hacer Circuitos impresos
Adjunto imagen...
[Imagen: Foto-CNC.jpg]
La maquina funciona bien, el problema que tengo es que si le digo de hacer por ejemplo el grabado de una linea que mide 48mm, la maquina me hace un grabado de una linea de unos 240mm.. mi configuración es la siguiente...
**** Connected to COM3 @ 115200 baud ****
Grbl 1.1g ['$' for help]
$0 = 10    (Step pulse time, microseconds)
$1 = 25    (Step idle delay, milliseconds)
$2 = 0    (Step pulse invert, mask)
$3 = 4    (Step direction invert, mask)
$4 = 0    (Invert step enable pin, boolean)
$5 = 0    (Invert limit pins, boolean)
$6 = 0    (Invert probe pin, boolean)
$10 = 1    (Status report options, mask)
$11 = 0.010    (Junction deviation, millimeters)
$12 = 0.002    (Arc tolerance, millimeters)
$13 = 0    (Report in inches, boolean)
$20 = 0    (Soft limits enable, boolean)
$21 = 0    (Hard limits enable, boolean)
$22 = 0    (Homing cycle enable, boolean)
$23 = 0    (Homing direction invert, mask)
$24 = 100.000    (Homing locate feed rate, mm/min)
$25 = 1000.000    (Homing search seek rate, mm/min)
$26 = 250    (Homing switch debounce delay, milliseconds)
$27 = 1.000    (Homing switch pull-off distance, millimeters)
$30 = 1000    (Maximum spindle speed, RPM)
$31 = 0    (Minimum spindle speed, RPM)
$32 = 1    (Laser-mode enable, boolean)
$100 = 400.000    (X-axis travel resolution, step/mm)
$101 = 400.000    (Y-axis travel resolution, step/mm)
$102 = 80.000    (Z-axis travel resolution, step/mm)
$110 = 5000.000    (X-axis maximum rate, mm/min)
$111 = 5000.000    (Y-axis maximum rate, mm/min)
$112 = 5000.000    (Z-axis maximum rate, mm/min)
$120 = 800.000    (X-axis acceleration, mm/sec^2)
$121 = 800.000    (Y-axis acceleration, mm/sec^2)
$122 = 5000.000    (Z-axis acceleration, mm/sec^2)
$130 = 400.000    (X-axis maximum travel, millimeters)
$131 = 300.000    (Y-axis maximum travel, millimeters)
$132 = 5000.000    (Z-axis maximum travel, millimeters)
ok
>>> $G
[GC:G0 G54 G17 G21 G90 G94 M5 M9 T0 F0 S0]
ok
No tengo mucha idea de que parámetros están bien o mal, pero lo que supongo es que los pasos de los motores no son los correctos.. he intensado buscar información para saber que tocar y la verdad es que no tengo ni idea a parte que no encuentro la información..
Podría ayudarme alguien para configurar la maquina como debe de ir?
Si los step/mm estan bien puestos, el problema es al generar el gcode, que no esta bien la escala del cad.
Ese es el problema que no se si están bien puesto los step, se supone que el codigo si esta bien generado por que lo he seguido hasta de un tutorial, el cual al usuario le sale bien pero a mi no..
El problema que que no se cuantos pasos da los motores de eleksmaker, por eso de alguien que tenga la maquina y compare lo que tiene con lo que tengo para saber que esta mal..
Yo creo que los valores de $100 y $101 deberían ser 80. Por eso te hace el tamaño 5 veces mayor.
A ver si con esta calculadora puedes conocer tus valores
https://blog.prusaprinters.org/es/calcul...rap_32503/
[b]grafisoft gracias por la calculadora.. Guiño[/b]
  CONSULTA Actualizar Firrmware 0.9 a 1.1 grbl Eleksmaker a3Pro 2.5W dvidbare 9 8,154 07-02-2020, 07:53 PM
Último mensaje: Sselenne
  grabadora eleksmaker A3 pro: problemas con el laser Jasobrino 13 4,081 29-07-2019, 11:27 AM
