18-07-2018, 06:05 PM
(Última modificación: 28-05-2019, 02:41 PM por bolsoncerrado.)
Se compró para una demo pero al final no se ha ni desprecintado.
Viene con BLtouch incorporado, guias lineales, luz LED incorporada y zona de construccion de 400x400x500mm
PVP recomendado: 1200Eur
Vendo por 750€ envio incluido a la peninsula
![[Imagen: FORMBOTRAPTOR1.jpg]](https://preview.ibb.co/dNHnTd/FORMBOTRAPTOR1.jpg)
+ info del fabricante:
New affordable, massive scale 3D printer. Amazing 40x40x50cm build volume.
GENUINE BLTouch included. LINEAR Guide. LED Lightning!
Raptor, Large Format 3D Printer
Formbot is a high quality 3D-Printer where the manufacturer only use high quality components to make this great printer.
Framework of printer are made with sturdy 4040 aluminium profiles for maxium stability.
Very large build volume with a heated bed.
Autoleveling function which works really great. Sensors are geniune and proven technology from BL Touch.
High Quality extruder capable of most comon materials. Direct driven so you can experiment with flexible material.
This is what a real 3D-Printer workhorse should look like!
Top Features:
- Large build size 400 x 400 x 500 mm
- Auto leveling with geniune BL Touch
- Industrial linear guide
- TBI high quality Ball Screws
- Auto Bed Leveling with Genuine BLTouch
- Genuine Meanwell Power Supply
- Custom Designed Print Surface
- Compatible with Flexible Filament
- 4040 Aluminum Extrusion
- LED Lighting System
- 1KG Free Filament
Raptor comes assembled nearly, only takes 10-15 minutes to complete assembly, very easy to operate.
Note: for better performance, we have upgraded Raptor with TBI ball screw, which will eliminate the clearance, better for auto bed leveling. meanwhile, it’ll bring more silent working environment and longer service lifespan.[/size]
+ fotos en:
https://www.en3dstudios.com/product/formbot-raptor-400x400x500mm-build-volume-3d-printer/
[/size][/size][/size]
