Bienvenido, Invitado
Nombre de usuario
Contraseña
Estadísticas del foro
» Miembros: 18,142
» Último miembro: gonzalezmau
» Temas del foro: 12,439
» Mensajes del foro: 118,951
Estadísticas totales
Últimos temas
Impresión nylon con fibra
Foro: General
Último mensaje por: Tonete
Ayer, 10:40 AM
» Respuestas: 2
» Vistas: 277
U4GM How to Find the Revi...
Foro: Impresoras
Último mensaje por: Hartmann846
31-01-2026, 09:26 AM
» Respuestas: 0
» Vistas: 138
U4GM How to Unlock CoD BO...
Foro: General - Invitados
» Respuestas: 0
» Vistas: 134
RSVSR Why Bird City chimn...
31-01-2026, 09:23 AM
» Respuestas: 0
» Vistas: 97
fallo de escritura en Uni...
Foro: Firmware y Software
Último mensaje por: Simemart
29-01-2026, 07:27 PM
» Respuestas: 15
» Vistas: 993
¿Que impresora compro?
Foro: General
Último mensaje por: javicf
20-01-2026, 06:34 PM
» Respuestas: 0
» Vistas: 248
  U4GM How to Find the Revival and Safekeeper Blueprints in ARC Raiders
Enviado por: Hartmann846 - 31-01-2026, 09:26 AM - Foro: Impresoras - Sin respuestas
Since the Headwinds update landed, you've probably looted a couple of new purple Augments and wondered if they're keepers or just more clutter for the stash. I've seen plenty of squads argue about it in voice, then scrap them anyway. If you're the type who likes to compare stats before you risk a kit, it helps to think of them as niche tools, not meta miracles, and to cross-check how they fit alongside your usual ARC Raiders Items choices while you're planning a run.
Tactical Mk. 3 (Revival) feels great until the shield limit hits
The headline stat is simple: passive regen at 1 HP every 5 seconds, same vibe as Combat Mk. 2. The part that matters more, though, is the built-in defib. You get a revive tool baked into the Augment with a 240-second cooldown, and that's a big deal if your quick-use bar is already packed. You can carry smokes, scans, traps, whatever, and still have a safety button when a teammate gets deleted. But there's no getting around the restriction: it only works with Light Shields. That means you're choosing utility over raw staying power, and a lot of fights in ARC Raiders don't forgive "light" when you get caught in the open. The smaller storage doesn't help either, because you'll extract with less and still feel broke after the craft.
Looting Mk. 3 (Safekeeper) is a PvP insurance policy
Safekeeper is the one that changes how people behave in a gunfight. First, it pairs with Heavy Shields, which already makes it easier to justify. Then there's the Safe Pocket: it can hold any item, even a weapon. That's wild compared to the usual "only certain categories" limitations. In practice, it means you can bring your best gun, test your aim, and still have a panic plan if the raid turns nasty. You can also pocket a high-tier weapon off a downed player and stop worrying about getting third-partied on the walk out. The trade-off is obvious once you start looting normally: the main slots and trinket slots are stingy, so this isn't what you wear for a relaxed money run.
Blueprint hunting without melting your brain
Getting the blueprints can feel like chasing a rumour, mostly because the pool is so diluted now. Speed runs through Stella Montis still make sense, especially around medical and research spaces where Augment containers show up more often. A handy habit is checking the item count before you commit to sorting: when a container rolls more than three items, it's often worth the extra second because your odds jump. If it's sitting at three, a lot of players just move on and keep the pace. And honestly, that approach saves your mood; you'll usually stumble into these prints during regular play if you're consistent.
So are they worth it for your runs
If you hate wasting a quick slot and your squad plays tight, Revival can earn its keep, but you've got to accept the Light Shield life and the slimmer haul. If you live for player hunts or boss chases, Safekeeper is the cleaner pick because it lets you risk a strong weapon without that sick feeling when footsteps show up behind you. Either way, don't craft them just to say you did; craft them when they solve a specific problem you keep running into, and if you're trying to gear up without overpaying, it's worth looking at cheap ARC Raiders gear options that let you experiment without stressing every raid.
  U4GM How to Unlock CoD BO7 Season 1 New Weapons Fast
Enviado por: Hartmann846 - 31-01-2026, 09:26 AM - Foro: General - Invitados - Sin respuestas
Season 1 for Black Ops 7 hits on Thursday, December 4, and it's the first time in a while the game's felt like it's properly opening up. Maps are nice, sure, but the real shift is the steady stream of weapons finally giving everyone more than a couple "safe" picks. If you're trying to keep your grind painless while you test new builds, a CoD BO7 Bot Lobby can make it way easier to level guns without spending the whole night getting spawn-trapped by stacked squads.
Battle Pass Must-Grabs
If you're diving into the pass right away, the KOGOT-7 is the early headline. It's an SMG that basically begs you to sprint at every dot on the minimap. Up close it melts, and the iron sights are clean enough that you don't feel forced into an optic. Step out into longer lanes, though, and it drops off fast. The Akimbo Prestige Attachment at weapon level 39 turns it into pure chaos—less accuracy, more panic, more multi-kills in tight rooms. Later on, Page 6 brings back the Maddox RFB. It's that comfortable automatic AR vibe: steady recoil, forgiving mag size, and a "hold this lane" feel that doesn't punish you for taking a second to reset your aim.
Weekly Challenge Sweat Rewards
Week one's mastery reward being the Ballistic Knife is such a throwback move. There's no buildcraft here, no attachment puzzle, no "meta setup" to copy. You either land it or you don't. And when you do, it's nasty—one moment you're poking corners, the next you're flying in for a melee like it's the only option. You'll notice players get weirdly predictable during these challenges too. Lots of forced flanks, lots of desperation pushes. If you're smart, you can bait that and finish requirements faster than you'd expect.
Event Weapons That Could Flip The Meta
The event-locked stuff looks like it's made to annoy the current comfort picks. The Sokol 545 LMG sounds genuinely flexible, especially with a toggle that lets you choose between slower, cleaner shots or dumping damage when a hill gets crowded. The Prestige mod turning it into a six-round burst is the kind of change that'll split opinions—some folks will hate it, some will farm with it. Then there's the NX Ravager crossbow, which is basically a direct message to riot shield players. Explosive bolts force movement, and the Tribolt attachment fixes that "one shot then forever reload" pacing that usually makes crossbows feel like a gimmick.
Snipers And SMGs To Watch
Sniper players are going to latch onto the Hawker HX fast. It's bolt-action, but it's clearly built for aggressive peeks, not just sitting in the back praying nobody slides your head off. High flinch resistance matters more than people admit, especially when every gunfight starts with you getting tagged first. And the Strumwolf 45 SMG could end up being the quiet favorite—low recoil, headshots that actually feel rewarded, and a Prestige attachment that's still up in the air. If the rumored mag mod really trades stability for damage, it'll be one of those "either it's broken or it's useless" parts. If you're looking to speed up unlocks, snag gear, or just top up your account with game currency and items while you grind, U4GM is worth checking out before you queue up for another long session.
  RSVSR Why Bird City chimney nests are Arc Raiders best loot run
Enviado por: Hartmann846 - 31-01-2026, 09:23 AM - Foro: General - Invitados - Sin respuestas
After the Headwinds update, Buried City doesn't play the way it used to, especially when Bird City pops up. You'll feel it fast: people stop sweeping the street level and start scanning rooftops, ladders, and zip routes, because the whole event nudges you upward. If you're trying to build a reliable stash of ARC Raiders Coins, this modifier is one of the few times the map almost tells you where to invest your time, and it's not down in the alleys.
What You're Actually Looking For
The chimneys are the point. Not the usual containers, not the "maybe there's something in this corner" routine. During Bird City, the Italian-looking blocks with tiled roofs can spawn bird nests tucked into those chimney tops, and they behave like their own kind of loot container. You crack one open and it's a weird mix: parts, snacks, little sellables. But everyone knows why the roofs are busy right now. Rubber ducks. It sounds like a joke until you've watched your sell pile jump after a clean run.
Ducks, RNG, And Why Volume Wins
There are seven duck variants in the nest pool. You'll mostly pull the basic stuff, the kind you shrug at and keep moving—Classic, Tropical, Gentle, Alien, that sort of spread. The one you're really hoping for is the Familiar Duck, an epic piece that can go for around 7,000 Raider Coins. The catch is simple: you can't force it. There's no "go to this building for the good duck" trick. It's just rolls. So the smart play is to stay light, stay quick, and open as many nests as you can before someone else clears your route. They stack to 15 per slot too, which is why a single lucky stack feels like hitting a mini jackpot.
Routes That Don't Waste Your Time
If you're serious about farming, pick areas with chimney density and tight roof lines. Old Town and the Village usually feel best because you can chain rooftops without dropping to the street every ten seconds. Keep your momentum: zipline up, hop across, check a nest, move on. Don't linger. Once a nest is looted, it's done for that cycle, and the longer you stare at your inventory, the more likely someone's already on the next roof over. Also watch the schedule—Bird City isn't always live, and queues get sweaty when it is, so plan your runs around that window and don't be surprised if extraction gets contested.
Why People Keep Hoarding Them
It's not only about selling. A lot of players are stockpiling ducks as brag items, because it's funny, it's visible, and it turns into a little personal goal between raids. You'll see folks risk a bad rotate just to grab one more chimney before bailing, then laugh about it in chat like it was totally planned. If you're doing it for profit, cool, but if you're doing it because you want a ridiculous pile in your stash, that's valid too, and it still circles back to getting ARC Raiders Coins cheap without turning every match into a grindy slog.
Enviado por: ofitecno - 21-01-2026, 11:07 PM - Foro: General - Respuestas (2)
Buenos días, mi nombre es Carlos y tengo una impresora desde hace 8-10 años, modelo Vertex k8400 pero modificada prácticamente en todo. Es completamente cerrada, cama caliente y hotend E3D V6
Para imprimir PLA, ABS no tengo ningún problema pero tengo que imprimir una pieza en Nylon que viene reforzado con fibra, en concreto nylstrong (Smart Materials) y me está generando un problema que se traduce en desplazamiento de capa. La impresión se adhiere perfectamente a la cama, pero se le va quedando un poco de filamento pegado en el exterior del nozzle y cuando le viene en gana lo desprende encima de la pieza de tal manera que se queda adherido el "pegote" y cuando vuelve a pasar el nozzle por el mismo sitio a veces se produce desplazamiento de capa, adjunto dos imágenes donde creo que se puede apreciar
[Imagen: imagen-2.jpg]
[Imagen: imagen-1.jpg]
Los ajustes de impresión son prácticamente los recomendados por fabricante del filamento:
Temperatura 255°
Temp cama 100°
Velocidad 30mm/a
Flujo 100%
Nozzle de acero 0.6mm
Altura capa inicial 0.3mm
Altura capa 0.28mm (aquí es donde tengo más dudas)
Ventilador capa Off
Nozzle nuevo de marca triangelab
Alguno ha tenido estás imperfecciones??? Los ajustes son correctos o se pueden retocar.
Gracias de antemano
Enviado por: javicf - 20-01-2026, 06:34 PM - Foro: General - Sin respuestas
Buenas tardes. Estoy pensando en comprarme una impresora 3D que sea la mas completa posible y me permita imprimir en multicolor. He estado viendo varias opciones como son las Flashforge AD5X, Elegoo Centari Carbon o la Bambu lab A1. Tambien he visto que van a sacar la Anycubic kobra X y no tiene mala pinta, pero no se si fiarme. Quería preguntar si sabeis de alguna mas que sea recomendable y que ronde los 400 € ¿Cual me recomendais?
